agilent power sensor u2001A labview driver usb
Has anyone come across the Agilent Power Sensor U2001A? I am looking for its LabView 8.5 driver as I am unable to find it during my search.
Many thanks,
Trong
Message 1 of 9
(6,536 Views)
Agilent driver download site has the IVI-COM and IVI-C driver for power meter/sensor products.
http://www.home.agilent.com/agilent/facet.jspx?cc=US&lc=eng&k=U2001A&sm=g&t=80045.k.1
Download and install the driver, then your PC must have IVI-C interface modules in ProgramFiles/IVI/Drivers directory.  Then import AgRFPowerMeter.fp file from LabVIEW's Import CVI or Plug&Play driver menu to convert it to LabVIEW's language interface.
Message 2 of 9
(6,530 Views)
I can't to import the AgRFPowerMeter.fp using labview 8.6, any body can help me?
thank you
Message Edited by lmontoya on 06-04-2009 11:33 AM
Message 3 of 9
(6,041 Views)
Hello Imontoya,
       Instead of importing the IVI Specific Driver, I recommend that you just use the IVI Class Driver wrapper VIs that are included in the IVI Compliance Package.  Please see Using IVI Drivers in LabVIEW for more information.
Cheers,
NathanT
Message 4 of 9
(5,998 Views)
lmontoya:
Did you figure out? I still can't find a right way to have a "simple" VI for it.
Already downloaded everthing and can't find how to use that package.
Message 5 of 9
(5,979 Views)
I make this two VI, just to INIT and Read Power
Enjoy
Message 6 of 9
(5,974 Views)
Imontoya,
Thanks for your VIs.
I have a question aboout the unit of the output power and input of the frequency.
Frequency: MHz (I saw the MHZ in the block diagram)
Output power: Is it dBm, dB or Watts?
If anyone can give me a clue, I really appreciate it.
Message 7 of 9
(5,456 Views)
I ve the same problem...
I don't understand how a can communicate with USB.
I try with a simple command like *IDN? , no problem.With all other it's not.
Message 8 of 9
(4,945 Views)
i've try to used the IVI drivers creator.
I had select the library "agRFPowermeter.dll"and create the installer.
I can start this installer, it's run normaly but i don't find any destination of .vi or other indication .
It's cool , i've just installing a program but i don't no why and where is it.Smiley Mad
Anyone to help me?Smiley Wink
Message 9 of 9
(4,931 Views)
