PCI-GPIB for solaris 2
When I installed PCI-GPIB driver for solaris 2.6, I found that the floppy disk (P/N: 500509A-01) was damaged. Where can I download it?
(1,286 Views)
Accepted by hejy
Hello hejy
I couldn't understand the question clearly. Could you please describe what you meant by saying floppy disk (P/N: 500509A-01) was damaged?
And what are you want to download if you have already had the driver installed?
Regards)
(1,239 Views)
The problem has been solved. Thank you for your reply!
(1,224 Views)
