PCMCIA - Code 43
Was the other card you tried also a National Instruments PCMCIA-232/2 that worked, or was it a completely different PCMCIA card? If it is the same card, your original card probably needs repair. If not, you can try the PCMCIA card in a different system to test the card itself. If you think you need to send the card in for repair, you can contact the Applications Engineers to arrange it.
Message 11 of 13
(1,403 Views)
it's an Nationanl Instruments PCMCIA-232/2 card. I think i need to send the card for repair.
Message 12 of 13
(1,403 Views)
Here's the KnowledgeBase entry Sending a National Instruments Board in for Repair or Calibration . Just tell the Applications Engineers about the troubleshooting you have done.
Message 13 of 13
(1,403 Views)
