PCMCIA-GPIB for win 2000 running on cPCI bus via a cPCI PC Card Adapter
We are trying to use a PCMCIA-GPIB for win 2000 running on cPCI bus via a cPCI PC Card Adapter. Our OS is WIN2K SP3 and we are running version 1.7 (latest) of the drivers. Unfortunately when using the "getting started" wizard and the "verify software and hardware installation" the system occasionally doesn't pass the third test. When it does, we try to scan for instruments using MAX Explorer to talk to a Agilent CW generator via GPIB but it cannot find the instrument. Doing the same thing on a laptop PC is successfully achieved. Any information on this matter would be greatly appreciated.
(3,035 Views)
Although it should be transparent to the PCMCIA card, I have also have had some problems with some adapters. Specifically, I have been able to install the card in a PCI-PCMCIA adapter form Qualtech, but not if I'm using a cPCI Cirrus Logig adapter. We haven't been able to find a cause for this.
If you need a GPIB interface in a cPCI system, you might consider the PXI-GPIB. PXI fully compliant with the cPCI standard.
DiegoF.
(3,035 Views)
