‎04-03-2012 08:35 AM
I am new user of Labview.I want to control my R&SFSP(spektrum analyser)using Ni PCMPCI-GPIB.what drive should i install at first and what will be the next step.I have already installed labview 2011.
‎04-03-2012 08:56 AM
Do you know how to use the instrument's front panel buttons to make the measurements you want?
Many people jump in and install the instrument LabVIEW driver and try to use them without understanding how their instrument works. An instrument driver is not a substitute for knowing how to use the instrument.
‎04-03-2012 09:19 AM
Instrument Front panal button?you mean ,operating manual of my instrument???
‎04-03-2012 09:22 AM
Actually i am trying to see my device in Max ,but i couldnt see anything there except COM3 and LPT1.
‎04-03-2012 09:24 AM
You need to install NI-488 before you can see it in MAX.
‎04-03-2012 09:57 AM - edited ‎04-03-2012 09:59 AM
That would have been good information to have put in your first post.
Edit: By the way, that instrument is LXI Conformant, which means if you had wanted to save some money, you would not have needed a GPIB card. You can communicate to the instrument via Ethernet. We had great success doing that with Agilent network analyzers.
‎04-03-2012 10:03 AM
Ja ,i have also installed Ni 488.
‎04-03-2012 10:12 AM
I can see PCMCIA-GPIB card in max but i can't see any gpib device there listed.what would be the possible reason????should i need to install any treiber??
‎04-03-2012 10:14 AM
What is your OS and what version of the driver did you install. The device is not supported on windows 7 or Vista.
‎04-03-2012 10:35 AM
i have Windows XP . And i have installed labview version 11.0.
