PCMPCI-GPIB instrument control
I am new user of Labview.I want  to control my R&SFSP(spektrum analyser)using Ni PCMPCI-GPIB.what drive should i install at first and what will be the next step.I have already installed  labview 2011.
Message 1 of 16
(4,834 Views)
Do you know how to use the instrument's front panel buttons to make the measurements you want?
Many people jump in and install the instrument LabVIEW driver and try to use them without understanding how their instrument works. An instrument driver is not a substitute for knowing how to use the instrument.
Message 2 of 16
(4,832 Views)
Instrument Front panal button?you mean ,operating manual of my instrument???
Message 3 of 16
(4,828 Views)
Actually i am trying to see my device in Max ,but i couldnt see anything there except COM3 and LPT1.
Message 4 of 16
(4,827 Views)
You need to install NI-488 before you can see it in MAX.
Message 5 of 16
(4,824 Views)
That would have been good information to have put in your first post.
Edit: By the way, that instrument is LXI Conformant, which means if you had wanted to save some money, you would not have needed a GPIB card. You can communicate to the instrument via Ethernet. We had great success doing that with Agilent network analyzers.
Message 6 of 16
(4,822 Views)
Ja ,i have  also installed Ni 488.
Message 7 of 16
(4,814 Views)
I can see PCMCIA-GPIB card in max but i can't see any gpib device there listed.what would be the possible reason????should i need to install any treiber??
Message 8 of 16
(4,806 Views)
What is your OS and what version of the driver did you install. The device is not supported on windows 7 or Vista.
Message 9 of 16
(4,804 Views)
i have Windows XP . And i have installed labview version 11.0.
Message 10 of 16
(4,800 Views)
