PCMPCI-GPIB instrument control
After installing the card, did you right click on it in MAX and select 'Scan for Instruments'?
Message 11 of 16
(1,127 Views)
ja, i did so many times .but there is no any device found.
Message 12 of 16
(1,123 Views)
First, verify that the instrument is set for GPIB communication. nyc mentions that it is LXI compliant. You may have a menu item to enable/disable GPIB/Ethernet
If you have another GPIB instrument, connect that all by itself and try a scan. If you have a different GPIB cable, try that and do a rescan.
Message 13 of 16
(1,120 Views)
I got it now...thanks.
Message 14 of 16
(1,110 Views)
Finally i got it .
Message 15 of 16
(1,108 Views)
hi
   i have multiple string commands which i have to send from visa write..how can i send multiple command one after another.i am using Rs 232/rs485 serial communication.With in the string some of data i have to control from user interface.
thanks.
Message 16 of 16
(1,086 Views)
