PXIe-8301 Thunderbolt 3 thread pitch.
What is the thread pitch/screw size for the holes next to the Thunderbolt 3 ports on the card?  Are there any readily available retaining clips that are compatible?  Thunderbolt 3 is great but in a busy production environment it's easily disconnected or damaged with a bump or tug.  I think the larger one is 4-40 but not sure about the smaller hole.
(2,291 Views)
I think you need to get this cable retainer - I would assume these are compatible as Thunderbolt cables are fairly industry standard.
https://www.sonnettech.com/product/thunderlok3.html
Santhosh
Soliton Technologies
(2,268 Views)
Santo_13,
Thank you but unfortunately the screw for the Sonnet is a 4-40.  The screw hole on the side is smaller.  I've looked through various manuals and forums but have not found a single mention of the specs or any hardware made for this.  There has to be something, thank you again.
(2,252 Views)
Well, that is rather surprising, there is no trace of documentation of that screw.
You will get an answer if you contact NI Support
Santhosh
(2,249 Views)
Accepted by ETTech
That's an M2 nut above each connector. The holes at either side are 4-40
- Robert
(2,242 Views)
Thank you!
(2,224 Views)
