Passthrough functions in IVI COM
Bilal
Thanks - I discounted the (IO488) message as I am using a LAN connection but I will investigate this further. The nature of your response tells me that I am in the right area at least.
Cheers
DWW
Message 11 of 20
(2,423 Views)
I meet the same problem!, I should use Agilent N5530S to do a auto-testing program,but I only have its IVI COM driver ,I don't kown how to use it in Lab windows/cvi, Could you give some advice .
Thank you a lot.
Message 12 of 20
(2,385 Views)
Adam
Bilal got it right. I used the following code to set the phase (I presume you have created the CVI drivers from the COM Type library using the Active X Controller Wizard)
static int RFSigGen_SetPhase(CAObjHandle driverObj, double phase)
ERRORINFO errorInfo;
CAObjHandle systemObj = 0;
CAObjHandle IOObj = 0;
int error = 0;
char buffer[256] = {0};
Message 13 of 20
(2,383 Views)
Adam
int error = 0;
Message 14 of 20
(2,383 Views)
Adam
int error = 0;
Message 15 of 20
(2,383 Views)
Adam
int error = 0;
Message 16 of 20
(2,383 Views)
Adam
int error = 0;
Message 17 of 20
(2,383 Views)
Adam
int error = 0;
Message 17 of 20
(2,383 Views)
Adam
int error = 0;
Message 19 of 20
(2,383 Views)
Adam
Sorry about the last attempt to answer, I keep hitting some button which closes the reply/edit window before I'm ready.
Bilal got it right. I used the following code to set the phase (I presume you have created the CVI drivers from the VISACOM and Instrument Type libraries using the Active X Controller Wizard):
static int RFsigGen_SetPhase (CAObjHandle driverObj, double phase)
int error = 0;
 sprintf(buffer,":PHAS %lfDEG", phase);
 AxErrChk(AgilentRfSigGenLib_IAgilentRfSigGenGetSystem (driverObj, &errorInfo, &systemObj));
 AxErrChk(AgilentRfSigGenLib_IAgilentRfSigGenSystemGetIO (systemObj, &errorInfo, &IOObj));
 AxErrChk(VisaComLib_IFormattedIO488WriteString (IOObj, &errorInfo, ":PHAS:REF", VTRUE));
 AxErrChk(VisaComLib_IFormattedIO488WriteString (IOObj, &errorInfo, buffer, VTRUE));
Error:
 if (systemObj) {CA_DiscardObjHandle(systemObj); systemObj = 0;}
 if (IOObj) {CA_DiscardObjHandle(IOObj); IOObj = 0;}
 return error;
AXErrChk is just an error checking macro and driverObj is the top level driver handle from
 AxErrChk(AgilentRfSigGenLib_NewIAgilentRfSigGen (NULL, 1, LOCALE_NEUTRAL, 0, &driverObj));
 AxErrChk(AgilentRfSigGenLib_IAgilentRFSigGenInitialize (driverObj, &errorInfo, resourceName, VFALSE, VFALSE, ""));
The inmportant bit is the VisaComLib_IFormattedIO488WriteString call
You'll note that I've just called the drivers direct but you may prefer to use the class drivers for your instrument
Hope this helps
DWW
Message 20 of 20
(2,382 Views)
