Pizo scanner in two dimention
Hi
Any body tell how to  move the scanner  using differnt in one or two dimensionusing labview software.
(3,635 Views)
What do have?
A controller for the piezos? Which one, how is it connected to LabVIEW? Does the manufacturer provide a LabVIEW driver?
An analog voltage out device (which one?)  to drive the piezo (amplifier)?
Well by using the LabVIEW CD covers as protection handles you might be able to manually grab the scanner and move it 😄
Greetings from Germany
Henrik
LV since v3.1
(3,623 Views)
Duplicate from http://forums.ni.com/t5/Motion-Control-and-Motor-Drives/How-can-one-communicate-with-a-nanonics-base...
The code you sent appears to be using register level programming for this.  You will need to find out the locations and what we need to write to the board but the location of the VIs to use this in LabVIEW 8 is described in http://digital.ni.com/public.nsf/allkb/E6415E8A8376F63D86256C46007592E8?OpenDocument
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(3,566 Views)
