Using HP34401A in LabView yields error code -1073807343
Hi all,
I used the HP34401A Single Read Example.vi to read data from HP34401A.  However, the following error occur,
'Error -1073807343 occurred at VISA Open in HP34401A Initialize.vi->Untitled 1
Possible reason(s):
VISA:  (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system. '
I am using NI GPIB-USB-HS and I can communicate with HP34401A in MAX.
I can't figure out why this error happen and how to solve it.  Please help me.
Thanks a lot.
Message 1 of 23
(7,628 Views)
How are you selecting the VISA Resource Name? You should be clicking on the arrow on the right side and selecting from the list.
Message 2 of 23
(7,622 Views)
I can't see the GPIB under the VISA resource name.
Message 3 of 23
(7,600 Views)
What do you see? What program in MAX did you use? There are two.
What version of LabVIEW and what version of NI-VISA?
Message 4 of 23
(7,594 Views)
VISA resource name do not show anything for me to choose as shown in VISA resource name.bmp.
I am using Labview 8.2.1 and theh version of NI-VISA is 4.3
I am using the Communicate with Instrument funtion to communicate with HP34401A.
Please see the attaahed graph.
Message 5 of 23
(7,582 Views)
Below are the attached graph
Message 6 of 23
(7,581 Views)
One more graph.  Thanks for your help.
Message 7 of 23
(7,580 Views)
You are not using the VISA utility in MAX so that is why it is working there.
VISA seems to be installed. You can try deleting visaconf.ini (search for it) and doing a new search for instruments. You can also updating NI-VISA.
Message 8 of 23
(7,557 Views)
The computer cannot find the visaconf.ini. and I am trying to update the VISA.
Moreover, are there any ways to communicate with HP34401A in LabView without using VISA?
Message 9 of 23
(7,500 Views)
Yes, if you use the low level GPIB functions.
Message 10 of 23
(7,496 Views)
