Using HP34401A in LabView yields error code -1073807343
Should I reinstall the VISA to older version?  I would like to try VISA 4.1 as in the successful case, the VISA version is 4.1.
Message 21 of 23
(1,901 Views)
Accepted by topic author aywl17
Yes- You should down rev the NI VISA revision.  4.1 does support LabVIEW 8.20 and can be downloaded for the NI site here
Message 22 of 23
(1,888 Views)
The problem was solved after I installed NI VISA 4.1.  Thanks for your help.
Message 23 of 23
(1,865 Views)
