Port read access problems under WinNT
I'm using LabWindows/CVI for accessing a self made ISA-bus interface card. Each port read access fails, though the correct data is visible at the ISA-bus. Each port read (using inp()) returns 0xFE.
- operating system is WinNT 4.0
- the low-level support driver is loaded at startup
- write port access (using outp()) works
Can somebody help me in this topic?
Markus
(3,226 Views)
Hi Markus,
I collected some information on this problem. Please see if it works :
Try running the example program in this link and see if it works fine.
http://ae.natinst.com/devzone/explprog.nsf/41ee12ddba6c766a8625684700691463/4066173b8d98118a86256a79004f7a7a?OpenDocument
http://ae.natinst.com/devzone/explprog.nsf/41ee12ddba6c766a8625684700691463/78e7f3ac0de597fd86256aa20074e50b?OpenDocument
(3,226 Views)
