Power sensor reading through RS-232/USB
I just fixed the issue.
It seems I have to set the port baud rate to 115200, no idea why this setting helps.
Thanks for all helps!!!
Message 11 of 12
(791 Views)
Accepted by topic author ElliotYY
Because the manual told you to?
Mostly likely, the internals of the device just use a USB-RS232 adapter chip that then sends the data to a microcontroller.  So you need the baud rate to match the settings of the microcontroller.
Message 12 of 12
(774 Views)
