Power supply control through Dasylab problem
Hello NI community:
I am attempting to set up Dasylab to control an Agilent N5765A power supply through USB. I am able to control the power supply using the SCPI commands through the agilent connection expert interactive I/O, NI VISA interactive control, and VISA assistant utility. Would anyone happen to know of a Dasylab driver that will directly interface with the power supply or a similar USB instrument?
I am using windows 7, Dasylab 13, and the NI measurement and automation software
(4,362 Views)
You might get a better response if you post in the Dasylab board.
(4,356 Views)
