Pressure Systems - Netscanner 9116
Does anyone have a simple VI for use with the Netscanner 9116. I have 9 modules (16 ports each) that I would like to import into a NI VI inorder to aquire data???
Please help. I am a newbee when it c:mansad:omes to Labview.
Message 1 of 9
(8,911 Views)
Did you check what the vendor has?
Message 2 of 9
(8,910 Views)
Yes, but with the vendors software you have to click a button to aquire the data from the scanners, then play it back using their own playback sequence, this will inturn create a .csv file. It is the only way that their software will collect data from the scanners. The Netscanner website lists a labview driver, so I was hoping someone out there had a VI that would lead me in the correct direction (I could adapt it to what I need -- reading from 9 modules - 144 ports).
Message 3 of 9
(8,903 Views)
I don't understand what you want. The link to the LabVIEW driver is right there. Are you saying it does not work or that you need help modifying it? I have not downloaded it since I am blocked from running exe's on the net. Can you post the code that it installs?
Message 4 of 9
(8,900 Views)
The netlab.exe gives you a .llb file with many subVIs.  Seems like this library (attached) has all the goods you'd need.
Good luck bud!
~Uncle J
Message 5 of 9
(8,865 Views)
Forgot the attachment last night
Message 6 of 9
(8,859 Views)
Pretty ugly looking code. In case someone needs to open it with LabVIEW 8.5 or later, here's the llb in version 7.1.
Message 7 of 9
(8,851 Views)
Accepted by mmesser
You all are awesome....!!!!! Thanks for your help!!!
Message 8 of 9
(8,823 Views)
noob question here.
I know this is a really old chat, but I have some 9116 netscanners that I'm considering writing a vi for to just simply display the data in waveform charts. I'm confused when I open this library though. I know barely enough to be dangerous.
Is there something that outlines which vi's I would need or some sequence of events?
Message 9 of 9
(2,408 Views)
