Problems with IVIFGEN Initialize.vi
Hi all,
I want to run a program using only the standard IVI drivers (IVIFGen) as in the attached file.
I can do it using the specific drivers of the function generator (Agilent 33220) but I want to control it using only common IVI drivers.
The problem is that when I run the .VI appears the following problem:
        viFgen Initialize With Options.vi<ERR>
        Driver Status:  (Hex 0xBFFA0011) Primary Error: (Hex 0xBFFA0011) Function or method not supported.
        Elaboration: FunctionId: 3,  FunctionName: InitWithOptions"
Anybody can help me?
Thanks and regards!
Mensaje editado por UnaiDeusto
(3,296 Views)
Have you installed the IVI driver for that instrument
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E96B8659CE034080020E748...
Regards
Ray Farmer
Regards
Ray Farmer
(3,279 Views)
Isn't this the same issue that you started this thread about on the 9th?
Please keep one issue to a single thread.
NathanT
(3,269 Views)
