10-26-2008 09:14 PM
Dear all,
I have encountered another problem. Our instrument's driver is based on Labview 6i. Since the computer system is old, we plan to migrate the system to a new computer with Labview 8. However, the VI cannot run without Labview 6i since the following VIs are missing:
AO Update Channel(scaled value).vi
ERRMSG.vi
AI Sample Channel (single-point waveform).vi
The VI's are under library of DAQ\1easyio.lib, \menus\Universal\Library\Das16.1ib, and others.
I want to know how I can get those DAQ libraries of Labview 6i and put it into Labview 8.
Roy
We checked the library of Labview 7.
10-26-2008
10:18 PM
- last edited on
09-13-2026
03:57 PM
by
Content Cleaner
The 1easyio.llb (not .lib) is part of the traditional DAQ driver and you can simply install it from your LabVIEW distribution CD. You can also search the drivers and updates and get the latest version. The DAS16 folder is for your Measurement Computing board and obviously is something you will have to get from them.
