Programming the NI (PCI-8433/4) RS 422 in Labwindows CVI
Thanks i found a VISA example.
Another quick query.
i need to monitor continiuosly all the 4 COM ports of the instrument.
if i do a multitreading(4 threads) for each receive, will it cause any problem?
Thanks in advance
Message 11 of 13
(2,457 Views)
You shouldn't have any problems. I normally use LabVIEW and have had twice as many com ports running in parallel. I'm a bit rusty on CVI and multithreading so perhaps you should post to the CVI board for specifics.
Message 12 of 13
(2,452 Views)
Thanks for Your reply
does the each 4 port in the card has a seprate FIFO for them?
Message 13 of 13
(2,448 Views)
