Pumps that are controllable by labview
I'm looking to purchase pumps that I can control via a NI 9205 Module. Any suggestions?
(4,035 Views)
Since the 9205 only has analog inputs, you cannot control a thing with it.
You have posted an impossible question to answer. You must provide details on the type of pump you need. I would suggest you do the basic research first and then narrow them down to the ones that have some sort of remote control interface (analog, serial, usb, ethernet, etc.).
(4,031 Views)
That should be 9263. My mistake, and I'm looking for a positive displacement pump.
(4,024 Views)
That narrowed it down to 2,820,000 results from google. You will need additional parameters for your search.
(4,013 Views)
Eldex 3SM or a 3LM?
(4,006 Views)
Well, the 3SM says it can be controlled by either RS-232 or 0-5V signal so the 9263 could be used or an inexpensive serial port connection.
(4,003 Views)
