Small USB-GPIB device driver size for distro??
Hi all.
I've had a search and can't find a similar question so hopefully I'm not duplicating something...
I have created a little app to control an Agilen 53132 counter using the USB-GPIB NI device which I would like folks to be able to use internally in my group. Driver I use was downloaded from http://joule.ni.com/nidu/cds/view/p/id/2315/lang/en.
I can see that my app uses the following DLLs. However, can I a) distribute these and b) there must be some drivers below this level that will be required by a clean system.
gpibconf.sll, ni482.dll, nipal32.dll, nipalu.dll, nipalut.dll, nispylog.dll.
Only issue I have is that this is almost 0.5 GB in size. I would like to distro my app with a much smaller subset so that user can install just the relevant driver & dlls etc I'll need to use the USB-GPIB device. Does anyone know if a smaller driver set distro exists please?
Many thanks,
James
(3,763 Views)
Accepted by topic author James_Hume
There is no smaller driver available.
(3,746 Views)
Hi Dennis,
Thanks for your reply.
I noticed in the download folder from the NI installer there are a lot of products. I assume one of the installers must do the device drivers. Could I, for example, use just a subset of these? For example I won't need any of the LabVIEW or MStudio* installations would I?
Cheers,
James
(3,743 Views)
No, when you do an installation, you do not need to select all of the options. I do not know how you would edit the installer to not look for all of the folders that are part of it. Perhaps there is a way to create a silent install with just the options you want but I'm not sure about that.
(3,740 Views)
OK, thanks for your help.
(3,737 Views)
