‎02-15-2008 05:52 AM
‎02-18-2008
10:25 AM
- last edited on
‎10-13-2026
02:38 AM
by
Content Cleaner
Hello Suprasaad,
Does the Scope give the same error if you use the VISA Interactive Control and send the same command (and read the response)? After looking at the code, it seems that support for the DSO50xx models was added in May of 2007. If your scope is older than this, you should upgrade your firmware. Please try to reduce the TestStand code down to the bare minimum that reproduces the issue and then post that sequence file to this thread.
NathanT
‎02-19-2008 01:50 AM
‎02-19-2008 06:24 PM
