Questions about reading waveform from TDS3054C oscilloscope.
Hi There,
I am trying to use Labview 8.5 to read waveform from a new TDS 3054C oscilloscope, i downloaded the driver package (TDS 3000 series.....VI) from NI, and I use readwaveform.VI, however, I got an error message: “TDS time out, no listener...” I have verified the address is correct: “GPIB0::1::INSTR”I use USB-GPIB interface, so is that an issue for this case?
 Thanks.
 Mike
Options  Options
(3,419 Views)
Attached is a simplified VI.
(3,413 Views)
Hey Mike,
I noticed on the driver's download page that the TDS 3054C isn't listed as a supported device for that driver.  This may be causing your timeout error.  Are you able to successfully communicate to the GPIB device by sending the identification string *IDN? using the VISA Interactive Control utility in Measurement and Automation Explorer?  Be sure when using this utility that you send a known working command for that device and one that you'll know the appropriate response to the command.
David Pratt
Group Manager for Application Engineering Specialists | Automated Test
NIC
(3,388 Views)
