Questions about the PCMCIA-GPIB, as noted by Aceman dated 3/6/2003.
After installing and resarting my HP Pavilion I get a NEW HARDWARE FOUND and procedure as normal. When the driver is found and starts to load about half-way through I get an error. It shows a CODE 10. I checked the resources and changed them but the problem continues. HELP!!!
(3,070 Views)
What driver version and OS are you using?
You should try using the lastest NI-488.2 driver (version 2.1), which improved PCMCIA support. You can find the driver at www.ni.com, click on download software >> Drivers and Updates >> Current Software Versions >> GPIB.
DiegoF
National Instruments.
(3,070 Views)
