RS-423 Level Discretes
I need to send and receive several RS-423 level discrete signals. I know I can configure a RS-422 port to receive the signal levels, but can I set it up using LabView to receive a discrete signal rather than a data stream?
Also, is there any way I can output RS-423 level discretes?
(3,700 Views)
I do not think this is possible with standard hardware.
You may be able to do this using a high speed DIO line and the appropriate signal conditioning.
Ben
(3,700 Views)
