Re: Why does viRead on GPIB device take 1 minute and completes normally
Here is the data I think you needed.  Let me know if you want more.  The test panels in MAX seem to work normally with no delays.  Ignore the errors on GPIB devices greater than 27 as they are not present.  This data is from an NI-8186 running Windows 7.  It works the same as the NI-8108.
(3,029 Views)
debatbae,
It looks like you accidentally created a new thread instead of replying to your existing one. Try posting this as a reply to the thread you are referring to.
Renée M
Applications Engineer
(3,016 Views)
(3,007 Views)
