Read Data from Oscilloscope (LeCroy LC564A) with GPIB
I would like to use LabView to read in the data from a certain Oscilloscope channel over the GPIB bus. I use the LeCroy LC564A Oscilloscope. The data should be saved in a text file. Afterwards I would like to change the Oscilloscope timebase automatically and to start the data acqusition from the Oscilloscope again.
(3,855 Views)
So you want someone to do this project for you?
What have you accomplished so far?
Message Edited by nyc on 03-02-2006 11:01 AM
(3,849 Views)
I can change the oscilloscope timebase but it is not possible to read any data in. I get always the follwing error message:
EDVR: Error connecting to driver or device
But if I can change the timebase, there should be no error with connect to the driver or device, right?
(3,843 Views)
There is an IVI driver for the 564 and a LabVIEW driver for the 574 that you might be able to use. Go to http://www.ni.com/devzone/idnet/default.htm
 and do a search for LeCroy. The tasks you describe are pretty simple. If you have some specific problem, describe it in detail.
(3,842 Views)
