Read Thorlabs optical power meter in LabVIEW 2018 via USB connection
Hello all,
I have been trying to read data from Thorlabs PM101R optical power meter using Labview 2018 (32 bit). Everything was fine. But suddenly I get an error as -
Possible reason(s):
"VISA: (Hex 0xBFFF0039) Unable to queue the asynchronous operation because there is already operation in progress." I read the threads but did not get solutions. Any help will be appreciated.
(3,865 Views)
instrument is still doing something
(3,836 Views)
Can you specify something because i am new to LabVIEW. I have attached encountered error screenshots to get a clear picture.
Thanks in advance.
(3,829 Views)
Have your employer send you for LabVIEW training.
(3,813 Views)
Accepted by MVJ99
It says there is already an operation in progress, meaning another program is currently controlling the instrument.  Are you still running another program?  NI-MAX or an instrument panel?  Perhaps a ThorLabs program?  You can't run 2 programs to control the same instrument at the same time, they fight for control and your LabVIEW code lost.
If you can't find a program running. Cycle the power and try again.
(3,809 Views)
