Read and Write Serial Port created via Bluetooth
All right... I understand the situation.
Recently I successfully comunicated with the bluetooth serial port. However, I am having a little problem:
In the main window I put a meter to aquire the data from my smartphone program. The program works well but for some reason I cannot measure a value between 1 and 10... I can only measure values with a range 10 to 100. What could be wrong with the code? Is there any way to measure values with 1-10 range?
Here is the code and the main window.
Message Edited by Borges on 08-18-2008 01:11 PM
Message 11 of 58
(3,609 Views)
Hi Borges,
Are you getting data returned in the 0-10V range? Check to be sure the string value is being converted correctly. You can create an indicator for the string data and be sure that it corresponds to the numeric data after the conversion. If you are reading back decimal data, you may need to use a Fract/Exp String to Number Conversion VI. What are you experiencing when 0-10V data is returned? Does the indicator stay at 10 or 0?
Steve B
Message 12 of 58
(3,581 Views)
When my sensor is marking a value between 0 and 10V the meter does not respond. The meter indication is only responding to values between 10 and 100. What could be wrong here? I could use some help to fix the problem.
Message 13 of 58
(3,578 Views)
Hi
can you psot the vi you are using?
maybe it is the decimal character, that is giving you problems.
greetings from the Netherlands
Message 14 of 58
(3,575 Views)
It´s currently posted on the post located in the top of this page.
There are two files in there.
Message 15 of 58
(3,573 Views)
Can you increase the bytes to read to 10 bytes (instead of 2) and make an indicator (or probe) on the string you get back form the read VISA.
Then post the result as a new picture. This will help alot to debug the problem.
BR
Thomas
Message 16 of 58
(3,564 Views)
I did that procedure before. However, after that the transmition stays awfuly slow. But the reading works all right. How I could optimize the transmition? I was thinking in modify my instrument to transmit at 115200 bauds.
But is there any way to perform some sort of code optimization?
Message 17 of 58
(3,541 Views)
Can you post wat the content of the received string is when you ask for more than 2 characters.
Is there some end character possibly?
You can always poll how much characters are available in the port (bytes at serial port)
Message 18 of 58
(3,538 Views)
It seems that when I set the byte count to 10 a error is triggered and the port is closed. That is strange.. for some reason when I set a byte count greater than 2 this error occurs and the serial port is closed.
Here is the screenshot and the .vi
Message 19 of 58
(3,531 Views)
This is a timeout, so no more characters are sent.
You simply have to live with that. Maybe only when below 10?
Message 20 of 58
(3,487 Views)
