Showing results forĀ
Search instead forĀ
Did you mean:Ā
Read data from 8714ES
Dear All,
    Here there is a network analyzer 8714ES. I want to read the data from the front pannel, is there some method to do that?
_________________________
EZCONN TEST ENGINEER
V
(3,826 Views)
There is an unsupported CVI driver that Agilent provides. Yo may be able to use the Import Wizard if you are using LabVIEW. If you want a pure LabVIEW solution, you'll have to get the manual and create your own driver or use the  Instrument I/O Wizard.
(3,823 Views)
I am using LabVIEW now, i try to use LabVIEW to read the data/curve from  the front pannel, is it usual with other equipment? Or i should use another commands?
V
(3,818 Views)
I don't know what you mean by 'usual with other equipment' or 'use other commands'. The only commands you can use are the ones that are in the instrument's programming manual and what would presumably be in the CVI driver I linked to.
(3,815 Views)
