Reading 2 Channels with TKTDS2XX Driver.
Is it possible to read channel 1 and channel 2 from my TDS 210 oscilloscope with the TKTDS2XX driver? I'm starting from the example, but it has a channel selection control which doesn't allow for selection of both channels at once.
(3,675 Views)
Although I'm not familiar with this particular instrument I did find the following knowledge base article: How Do I Use a Scope Specific Instrument Driver to Acquire Multiple Waveforms Simultaneously?
I'm also attaching an example VI. It uses the IVI Scope class driver in LabVIEW 6.1.
Hope this helps.
DiegoF
National Instruments.
(3,675 Views)
Thanks very much. I've got it working now.
UofG
(3,675 Views)
