Reading Sartorius scale via serial, error 1073807253
It seems you are in setup mode.
what scale are you using?
look at this site for a documentation:  http://www.sartorius-mechatronics.com/index.php?id=6262
greetings from the Netherlands
Message 21 of 24
(2,346 Views)
Hi Albert,
The file you attached is proven an instant solution to my problem 🙂 I can use it readily, many thanks! Mean while I want to have a continuous reading/recording of the measured weights in time basis, but unfortunately I'm not a fluent LabVIEW user. Therefore, could you suggest me the way to modify the file so I can achieve the goal? Many, many thanks in advance.
Kind regards,
Gema
Message 22 of 24
(2,089 Views)
Hi Gema
The way to do this is to read the start time with  Get Date/Time In Seconds (e.g before youget in a while loop)
Feed this in a while loop and ech time you read the balance also read the new time and subtract the start time.
Put the values each in a 1D array  and combine these in an xy -graph
Afterwards you can put them in a file. attached is a word document  I wrote a long time ago.
At that time we did ot have the Get Date/Time in seconds so I had another solution.
Message 23 of 24
(2,056 Views)
Many-many thanks indeed, Albert!
greetings,
Gema
Message 24 of 24
(2,043 Views)
