Reading number from instrument without the driver.
I am using the instument sr830, a lock-in amplifier via LabVIEW. This instrument uses IEEE-488 port, aka GPIB.
Unfortunately, my LabVIEW version is too low to be supported by sr830 driver available here.
So I think I need to figure this out only with the built in vi`s.
All I want to do is just reading off the numbers on the lock-in amplifier screen.
There are two channels for the instrument. I just want to tell Labview to read the number from which channel.
This looks very easy but I have been stuck for more than a week now.
To be honest, I don't really know what I should do.
Any help will be appreciated, thank you.
(3,677 Views)
Pull out the programmer's manual.  It should tell you all of the GPIB commands you need in order to read the data you want.
(3,668 Views)
