VISA Serial Port Write Error-1073807360
Can somebody give me some hints what mainly causes the error code in subject?
Thank you very much!
(7,026 Views)
Most of the time a bad cable between what you don't specify and VISA
greetings from the Netherlands
(7,004 Views)
I am Vasileios, an Applications Engineer with National Instruments. I am happy to assist you regarding your query.
According to this knowledge base article, linked below, the error-1073807360 is caused from the selected number of data bits. The data bits must be 5 to 8.
http://digital.ni.com/public.nsf/allkb/D2084EC381319CC386256A1D006F1415?OpenDocument
If you select to use 5 data bits you can either use 1 or 1.5 stop bits.
If you select to use 6, 7 or 87 bits, you can use either 1 or 2 stop bits.
I hope this will be helpful.
Regards
Vasileios T
National Instruments UK&Ireland
(6,966 Views)
Thank you for your answer.
I am facing same problem with the data bit is 8 and stop bit is 1.
Can anyone help me to fix this issue.
(5,925 Views)
Maybe you should start e new thread and tell a bit more about your problem: are you using LabVIEW, what kind of interface, what kind of device or instrument, etc., etc.
(5,920 Views)
