Running labview vi from measurement studio
Hi All,
i have a question about Measurement Studio 8.0.1 and Labview.
We have been working with labview for years now and hence have a considerable collection of all purpose VIs, which we use as building blocks (sub VIs) in our projects.
I would like to continue using these from MS 8.0.1 using C#.
How can i do it ?
(3,277 Views)
Hi MrDiam,
The simplest way to incorporate your old LabVIEW code into a C# application is to build your LabVIEW code into a DLL.  You may want to reference the Help File for Building a Shared Library (DLL) in LabVIEW 8. Also, this document on Calling a DLL with C# looks like a good reference for DLLs in general.
Hope this is helpful!  By the way, this question is better suited to the LabVIEW forums so you would likely get more responses there.
Megan Beck
Message Edited by Megan B. on 07-21-2006 08:14 AM
(3,261 Views)
