What is the threshold for a logic low and what's the threshold for a logic high in the RS485 communication?
I am using CVI to command the PCI RS485 / 8 port card.
(3,180 Views)
The RS485 communication is differential, not a single-ended voltage. Based on this link, the RS-485 voltage signal ranges from -7 to +12 V. If the negative line is less than the positive, this is a 1 or MARK. If the negative line is greater than the positive, then this is a 0 or SPACE.
I hope this helps!
Missy S.
Project Engineer
RoviSys
(3,162 Views)
