SCB-68 : Instrument Control
I have a SCB-68 E-Series device with a PCI interface.
I guess the cable connecting them is  GPIB.
I want to know if there is a document which details how to control the unit using GPIB SCIPI commands?
My goal is to communicate & control the device from a C# application.
Rama
(3,753 Views)
You are very confused. The SCB-68 is nothing more than a terminal block. It is used with a data acquisition card. The cable connecting them is nothing like a GPIB cable and an E-Series (or any other DAQ board) cannot be used as a GPIB controller. If you want a pci board for GPIB control, look at buying a PCI-GPIB board.
(3,747 Views)
An E Series DAQ device can be connected to a SCB-68.  The cable to connect them is not a GPIB cable.  If you want to program in C# and control the E Series device you can do this if you install DAQmx and DAQmx support for .net 1.1 framework.  Both these are available in the NI-DAQmx driver which you can download from our web site.
If you would like more information on programming in C# and using DAQmx please see the following KB:
http://digital.ni.com/public.nsf/websearch/8715FD7608B79AFC86256ECA004B87F1?OpenDocument
You will not be able to send GPIB commands with a E Series DAQ device.
Jesse O.
Application Engineering
Jesse O. | National Instruments R&D
(3,727 Views)
