modify/update context help
how can I access and update/modify "Context Help" window description of a VI?
I read the user manual (V.7.1), but I have not found much info.
plz help!
(3,862 Views)
Select VI Properties>Documentation and type what you want in the VI Description box. If you want context help for a control or indicator (and you should), right click on the control/indicator and select Description and Tip.
(3,855 Views)
Thank you!
(3,838 Views)
