SI 440 detector with monochoromator
Hi I have a actonsp2300 monochoromator and SI-440 detector. I can use this monochoromator for scan wavelenght but i cant control detector.
i am reading string inputs codes from detector. I used this monochoromator with lakeshore and keitley2400 but i need now use with detector. Any body can help me? I need read current or voltage from this detector.
Thanks.
Message 1 of 14
(4,760 Views)
Perhaps you are configuring it some place else but in the image you attached, I don't see any termination character being used. Check the manual and see what it is supposed to be
p.s. Wire up your error clusters and if the instrument sends a termination character, you don't need all of those VISA Bytes at Serial Port.
Message 2 of 14
(4,753 Views)
I dont used any therminal character my other programs too and them working. Because i think all default value current for this terminal.
Does this make a problem?
I was wired error cluster but instrumen dont send any error code.
I am reading string from indicator .READ so i must read any current value from inducator. I think a overlock a prossess. But dont know yet.
Message 3 of 14
(4,747 Views)
Sory i forgot attachment manuel. Pdf is attached.
Message 4 of 14
(4,746 Views)
make a start with subvi's that write a command and read the answer but only read when either the endchar is available or enough characters are available.
With your write /read all chars now available you can easily read too fast and so read not all characters needed for the answer.
Please remeber that data on a serial line take time to get there.
greetings from the Netherlands
Message 5 of 14
(4,737 Views)
I have no idea what 'my other programs too' are. Terminal emulation programs such as Hyperterminal/Procomm/etc. automatically send a termination character and it is something you have to program into LabVIEW.
You want to get error codes from the VISA functions.
Message 6 of 14
(4,735 Views)
detector.PNGYou think its ok now? I am not trying  time is 00:36  now here
Message 7 of 14
(4,726 Views)
Its dont work 😞 someone can help me? why i cant read current.
Message 8 of 14
(4,716 Views)
Hard to debug a picture. Attach the actual VI or a snippet (look it up) but in order to actually send a control character, you have to right click on the string constant and select '/' Code Display. Did you do that? Did you verify with the vendor or a sniffer that a line feed is the termination character that you need?
Message 9 of 14
(4,714 Views)
Programs attached. Can u check pls
Note: Version is 2010 if u wanna i can convert.
Message 10 of 14
(4,710 Views)
