SI 440 detector with monochoromator
I thought I inserted an image, but it does not show up, so I attached the vi also.
I removed the bytes at port and did put in 255 because that is big enough for what you are reading.
Second I added error in /out also on the connector and added connections to the read values, stil as string and that is not ideal.
greetings from the Netherlands
Message 11 of 14
(1,207 Views)
Sorry forgot to ask the question below
Did you see that you are using 0xD (CR) for the write and 0xA (LF) for the read end character?
Maybe it is OK but also maybe use \r\n for sending than it is probably the same for reading but you can only define one end character.
Message 12 of 14
(1,206 Views)
First thanks for your help.
U are right about CR and LF characters.
I will try it next day and i write the result.
Message 13 of 14
(1,202 Views)
The ouput signal of PMT tube is Current.
Message 14 of 14
(1,166 Views)
