07-24-2007 07:47 AM
07-24-2007 08:35 AM
07-25-2007
10:02 PM
- last edited on
12-17-2025
09:38 PM
by
Content Cleaner
Hi HeartShield,
Thanks for using National Instruments Discussion Forum. Like smercurio_fc said if you post this discussion in the LabVIEW forum there better chances that more people that might have solutions to this problem will see it. Anyway, since you don't have the Report Generation Toolkit the best way to interact with Excel from LabVIEW is by using ActiveX calls. A good place to start learning about ActiveX and LabVIEW is here. Also, in the NI Example Finder there is an example program that uses ActiveX to interact with Excel called Excel Macro Example.VI. Both of these should give you a good idea how to achieve your goal. I hope this helps you out.
07-27-2007 01:36 AM
