Separation problem of two different set of data in serial plot
Basically, I am working on a project which has two different systems each system has a one ZigBee and both of these systems ZigBee are sending different data to single Zigbee which is connected to LabVIEW.So as in to separate both the system I have used a special character and word in starting of both of the reading.
reading are coming in this particular format
system 1 :- $ROVER,2232,56.87,92.45...
system 2:- #PAYLOAD,84.96,9832,15.32...
Now the problem I am facing is I am not able to plot both of these system data simultaneously.
I have tried every possible thing I can but not able to do it.
I have attached my designed VI as well as screenshot of the logic
I have implemented two different approaches in a single VI but none of them is not giving appropriate result.
Please help me out
(3,526 Views)
Accepted by topic author vibhork10
You should be using a case structure based on the header of the message.  This way you only process the "Payload" when it is payload and "Rover" when it is rover.
Other notes:
1. There is no need for the Wait when you are reading in data.  The timeout of the VISA Read will limit the loop rate.
2. You really need a way to stop the loop other than generating an error.
(3,509 Views)
If your setup runs long time, you will run into the problem that the different timebases of your systems slightly differ.
At a certain time you will have read n values from device one and n+-x from device two.
If you want to do a timeplot I propose to add a (local) timestamp and use a XY-data graph format.
Greetings from Germany
Henrik
LV since v3.1
(3,494 Views)
You can use a simple chart (Sporatic Waveform Chart).
(3,490 Views)
