Serial Communication Error -1073807339
Hi pd46,
You posted in a forum thread that hasn't been touched in almost one year. In general, I suggest creating a new thread if there has been any significant amount of time since the previous post. This typically allows a faster response from both customers and engineers at National Instruments.
Have you looked through the solution on this thread? Did that help at all? Typically this error code means that a timeout occurred. Check out this KnowledgeBase article for a possible solution.
David B.
Message 11 of 12
(770 Views)
Hello dshusker,
No That did not help. Please if could take a look at the vi I had posted in the last message. Also, in the write/read.vi I am getting this same error  but it's alternating between 2 of the while loops. It's strange to me why the error is not constant at only one point on the block diagram.
I have taken 2 screenshots of the alternating same error code and attached to this message. Please take a look at it too.
Best Regards,
Poulomi Das.
Institute for Microsystems Engineering.
University of Freiburg.
Freiburg, Germany.
Message 12 of 12
(764 Views)
