hey guys...how to programme in LabView to retrive datas coming from different relays through RS485 DB9 port using NI PCI-8431/8 and modbus communication?
hey guys...
how to programme in LabView to retrive datas coming from different relays through RS485 DB9 port using NI PCI-8431/8 and modbus communication?Please drop the block diagram code also if it is possible.
thanks in advance
(3,369 Views)
Have you bothered to make an attempt at this or are you waiting for someone to do your work for you?
(3,360 Views)
