how to control DAQ, GPIB and VISA in other language
Hi there,
  I have GBIP, NI PCI6713, NI PCI6711 card installed and we have labview 7. I am just wondering if labview is the only way to control the GBIP and those DAQ cards? Is that possible to use C++ to do that, if so, what needed to be installed and if there is example to do so?
(3,367 Views)
Not sure about GPIP but there is support for GPIB and DAQmx in several different languages including c++. You obviously need to install c++. There are examples that come with the drivers. You may need to do a repair in order to install them if you didn't manually select them when you did the initial install.
(3,360 Views)
