Serial Read returns string with excess information- need to pull data from middle of string
I am reading data from a TSI flow meter using the Basic Serial Write and Read that uses VISA.  The string read begins with "OK" or an error code and then a carriage return, then the data follows in the form of flow rate comma temp comma pressure comma flow rate comma temp...and so on. The string ends with a CR LF.  I need to pull the flow rate, temperature, and pressure data out of the string and write it to a file.  I am having trouble finding a function that will pull the data from the string.  Any suggestions?  Thank you.
(3,700 Views)
Accepted by Ventana
try string subset in the string palette.
Or match pattern if you want more direct control.
Also a good way is the scan from string but you must be prepared to read oexactly what comes in or in case of error skip the input.
greetings from the Netherlands
(3,685 Views)
bedankt!
I think my solution is fairly tedious (see attached), but it works. I'm not sure I understand how Match Pattern or Scan From String would be used. But, now I have the string with only the data. From here, I need to get this data to an array and output to file. How do I convert a string of the form F, T, P, F, T, P... into an array with three columns of data?
I also realized now that I don't have any timestamp data, and I believe that will be a bigger issue. I will probably post that as a separate question.
groeten uit arizona!
(3,660 Views)
