Serial communication - A simulator based on request msg from other device, it should send response.
I want to create a simulator, which checks the request msg received from other devices via serial port and based on the request simulator should response msg.
For example:
Other Device Request to my simulator  : 2B 2B 2B
My Simulator  Response : 65 6E 74 72 61 4E 45 54 3E 20
Also, there are series of request message send sequentially to the simulator and after response is sent by simulator for each request - login successful.
Any heads up on how to proceed is highly appreciated.
Message 1 of 11
(5,900 Views)
I would recommend a sort of state machine.  Each step in the state machine is to look for the message.  Do you have a better description of the full message protocol?
Message 2 of 11
(5,876 Views)
Hi Crossrulz,
It is a serial data protocol and data are in ASCII format.
Can you post a simple vi if possible for my better understanding, so that i can take it up from there.
Aniket
Message 3 of 11
(5,868 Views)
That is a start.  Do the messages you receive end with a termination character (typically a Line Feed, 0xA, \n)?
Message 4 of 11
(5,860 Views)
Yes, it ends with termination character...
Message 5 of 11
(5,857 Views)
Accepted by aniketjha
I originally wrote this for a nugget series that I have been working on here in there.  Should at least get you started.
Message 6 of 11
(5,847 Views)
Thanks Crossrulz, this will work.
I will let you know once i done with the vi.
Message 7 of 11
(5,834 Views)
Hi Crossrulz,
1 simple doubt i have and it is not related to this topic, is there any way i can provide enable/disable button to create/clear communication loss via serial port.
Sorry for pulling up this simple question in this thread.
Aniket
Message 8 of 11
(5,828 Views)
You can use a State Machine with states like "Connect", "Read", "Close", etc.  So when you detect a connection loss, you can go back to the Connect state or an idle state waiting for somebody to press a button to reconnect.
Message 9 of 11
(5,815 Views)
I am actually new to this Crossrulz, if i get some sample vi on state machines particular to my requirement i will pick it up from there.
Aniket
Message 10 of 11
(5,811 Views)
