Setting hp3649 power supply voltage through IVI-C steps
I'm using in TS 4 IVI steps to configure and measure the channel 1 of the power supply.It work fine.
I Configure the extension as software trigger and in the channel tab I configure output tab
Voltage level   Paramaeter.Voltage
Output Range Mode
(3,245 Views)
continue here
(3,227 Views)
