Simple RS-485 capture
Is there a simple application/example program that is non-CVI to log RS-485 data to a file using an 8341/2 with NI-Serial 1.7?  I want to dump 600Kb data to a file.
(3,768 Views)
Hi GBerry,
I found an example in LabVIEW that does the communication. Once you get the date you want you could simply wire it into a Write to LabVIEW Measurement File VI and you'd be set.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=C3358B5CBE2C5068E034080020E74861&p_node=DZ52363&p_source=External
Hope this helps.
Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(3,743 Views)
Oops. My bad.  I was looking for a non labview  and non labwindows/CVI example.  I was hoping for a VISA API interface that I could import into C# so I could "snoop" on a RS-485 bus.
(3,738 Views)
Hi Gberry,
Here's an example in Visual C++. This has no File I/O, but shows how to configure the ports and do serial I/O on them.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3DFE756A4E034080020E74861&p_node=DZ52363&p_source=External
Best of Luck!
-Matt S.
Message Edited by Matt_S. on 09-09-2005 10:19 AM
(3,727 Views)
