Simulate GPIB Kethley 6430 using IVI driver
Hi Everyone,
I'd like to know if there is a way to use IVI drivers to simulate a Keithley 6430, and also maybe a Keithley 2128. I don't have the device but I would like to make some tests, so simulating it would be very useful.
If it is possible? If yes how should I do it? Is there a tutorial?
Best Regards,
(5,915 Views)
First you have find IVI drivers for them. NI does not have them. Check with Keithley.
(5,907 Views)
Hi Dennis,
Thanks for your answer.
I do already have downloaded them, and they show something in Max but the drivers for the Keithley are Visa Drivers, and I can add an IVI control on the block diagram but I dont know what to do with it, as IVI is not Visa right.
What is the next step?
Best Regards,
(5,896 Views)
An IVI driver does not have s block diagram. An IVI driver cannot be written in LabVIEW so I have no idea what you downloaded. Please provide the link.
An IVI driver is based on VISA and is written with LabWindows/CVI if it is an IVI-C driver. There are also IVI-COM and IVI-NET types. Please see www.ivifoundation.org for definitions.
(5,892 Views)
Hi Dennis,
Thanks for your answer,
I have downloaded the file from this link: http://www.keithley.com/base_download?dassetid=16504
As state on this webpage: http://www.keithley.com/products/dcac/sensitive/highresistance/?path=6430/Downloads#3, I have first downloaded and installed the
and installed then the IVI driver from the previous link it gave me acces to some configuration under MAX, but I don't see it, on the front panel, in VISA Control List I only see it in the IVI control List.
Also, on the Keithley configuration panel, installed with the I/O Layer, whenever I change the configuration of simulated to TRUE it gets back to False by itself.
I know I am lacking some knowledge in with IVI driver, Thanks a lot for you help,
Best Regards,
(5,884 Views)
(5,867 Views)
